| » Washer not spinning |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: LW3503W Brand: Amana Age: More than 10 years
Washer begins to spin, but stops only after 2 - 3 seconds. The belt is intact, but shows normal wear (some cracks etc). The tub is not out of balance. It keeps trying to start the spin cycle after a few minutes but stops. Any help is greatly appreciated!
Remove the belt and check if the motor runs without load.
__________________
Professional appliance repair services in Orange County, California. |
I removed the belt. It definitely needs to be replaced. It is not broken, but it has multiple cracks almost all the way through. The motor seems to run just fine without the belt on it. Does this mean that if the belt is replaced the washer should spin again. If not, what are the next steps.
Thank you for your help. |
There is a good chance the new belt will solve the problem.
- The part number for the belt is AP74961 Here are the break down diagram for the Amana washer Model LW3503W Good luck. Gene.
__________________
I replaced the belt. Initially, the machine kept stalling. It took 4 or 5 tries before it kept spinning. We've washed some loads. It works OK but the motor seems to run hot. I've never actually witnessed the motor when it runs so I don't know how hot is should get. Please advise and thanks for help.
Hot motor means: it was overloaded or the motor itself is bad.
In your case most likely the problem caused by the motor itself and it has to be replaced. - The part number for the motor is AP3873831 Gene.
__________________
| Display Modes | |
| Washer will agitate, but needs help spinning. | redi | Washer Repair | 1 | 12-14-2007 04:56 PM |
| washer not spinning | rtzjackson | Washer Repair | 1 | 12-04-2007 07:22 PM |
| Fridgidaire Washer not spinning | sprout69 | Washer Repair | 6 | 10-22-2007 04:58 AM |
| washer timer / not spinning | pbush412 | Washer Repair | 0 | 09-05-2007 10:32 PM |
