| » Maytag neptune washer |
Model Number: MAH5500BWW Brand: Maytag Age: 5 - 10 years
Hello to all , i am new here. I have a maytag Neptune about 5 yrs old or so.About a month ago on the spin cycle it started getting loud and now today after the spin it had a funky smell , i guess it was a burning type smell. I am pretty good @ fixing things ,anybody have an idea were to start?
Thanks for any and all help. Ads By Google Related Models
__________________
PURNRG |
You have bad tub bearings and seal. Without repair the increased load on the drive system will burn out either the motor, or the speed control board.
If you are good at mechanical repair, then it's probably worth repair. Take the back panel off and look for water marks from the tub bearing in back of the pulley.
__________________
Ok Thanks. I found this web site that this guy is selling a bearing kit for the neptunes and you can also rent his tony tool ,which is a bearing puller he made. Have you heard or seen this website ? If so do you know if it is legit? This is the website. TO ORDER
Thank you.
__________________
PURNRG |
You might not want to go that route. I used a steel pipe to pound out mine. I would pound out the inner bearing first, then the outer. Most of the time, the outer bearing is ok. If it looks good, pound it out with a wood dowel to preserve the bearing cover. This site can get you the seal for the tub.
Get the sk numbers from the bearings, or mike their dimensions, and order them from a bearing house on line. Opt for sealed bearings, they last a lot longer. Before ordering bearings, I would make sure you have no other major problems. Good luck.
__________________
| Display Modes | |
| Maytag Neptune Washer | emtwoman | Washer Repair | 1 | 01-14-2010 01:20 PM |
| neptune washer maytag | sezell | Washer Repair | 1 | 10-22-2009 11:22 AM |
| Maytag neptune Washer | Montana123 | Washer Repair | 1 | 08-13-2009 12:27 PM |
| Maytag Neptune Washer | hatnem | Forum Announcements | 0 | 08-20-2008 03:59 PM |
| Maytag Neptune washer | ccseeley | Washer Repair | 5 | 01-31-2008 12:51 PM |
