the washer tries to go into the agitate during the spin cycle. as a result it never gets up to full speed and the clothes comeout soggy. do you think this is a timer problem or a transmission problem.
More likely the problem is a bad tranny. The model number you posted is incorrect. Verify and repost it please.
Originally Posted by: Gene More likely the problem is a bad tranny. The model number you posted is incorrect. Verify and repost it please.
Gene. yes, it's 408 not 480
Originally Posted by: Gene it looks like you have to take off the thing with the 200 pound of spring tension warning on it to fix this. is this correct.
Yes, you have to be careful doing it.
