recently replaced motor and control board coversion kit and ever since then when water filling the water pipes are making a knocking noise. It sounds like bombs going off. I have to leave the house when washer is running. never had this problem until I installed the conversion kit. Any ideas?
Tom
Sounds like water hammer, I doubt it had anything to do with the parts you just put in your washer.
Just my 2 cents.
Originally Posted by: ApplianceJunk Sounds like water hammer, I doubt it had anything to do with the parts you just put in your washer.
Just my 2 cents. what is water hammer?
how much was that to replace all that? and how easy was it to do that? My neptune is about 10 years old maybe, suddenly quick working, i tossed it out in the garage until i had the money to fix it, its been a year, times are tough here, anyway, thinking its what you've replace, maybe not the motot though, im not convinced that is toast, fill me in the ordeal if you can, thanks
