Medium load of towels, washer sounded like it wanted to start spin cycle but did not, water still in machine. replaced belt on machine last week...HELP!
Hi Lynn Sorry you are having problems right after you had a repair. You could have two problems. If the water is not emptying, check the pump and the water lines for an obstruction. Your lack of spin could be caused by a bad transmission, but in many cases in these machines it is the spin bearing. There is a kit with instructions you can order if you want to try it, it is not too expensive. However, there are two different transmissions on this model, so call APP with your model and serial number to make sure you get the right one. Here is your service manual. http://www.servicematters.com/m...ibrary/docs/16023083.pdfGood luck, hope this helps.
