I need to replace both belts on this washer.Any tips and tools to do this job.
This job is simple you do not even need tools. Disconnect power then lean the washer back roll the pump belt off and then roll the drive belt. These belts are made to be loose this is why you can remove them without any tools. Clothes Washer Repair Guide
