AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
No ignition after interior clean and belt replacement
Groups ready for retrieval: Registered
You have been a member since:: 3/26/2012(UTC) Posts: 2
I OPENED UP THE GAS DRYER TO REPLACE THE BROKEN BELT AND TENSIONER PULLEY, I ALSO REPLACED THE WORN OUT DRUM GUIDE SLIDES FOR ABOUT THE 3RD TIME. AFTER I OPENED UP THE INTERIOR I VACUUMED OUT THE COMPLETE INTERIOR USING A BRUSH AND VACUUM. AFTER EVERYTHING WAS CLOSED UP I TURNED ON THE DRYER EVERYTHING WENT ON EXCEPT THE HEAT. WHAT HAPPENED? THE HEAT WORKED BEFORE. THANKS IN ADVANCE BEEK :confused:
I OPENED UP THE GAS DRYER TO REPLACE THE BROKEN BELT AND TENSIONER PULLEY, I ALSO REPLACED THE WORN OUT DRUM GUIDE SLIDES FOR ABOUT THE 3RD TIME. AFTER I OPENED UP THE INTERIOR I VACUUMED OUT THE COMPLETE INTERIOR USING A BRUSH AND VACUUM. AFTER EVERYTHING WAS CLOSED UP I TURNED ON THE DRYER EVERYTHING WENT ON EXCEPT THE HEAT. WHAT HAPPENED? THE HEAT WORKED BEFORE. THANKS IN ADVANCE BEEK :confused: Read more: http://forum.appliancepartspros...ement.html#ixzz1qHOk2Q5P http://forum.appliancepartspros.com
Sorry, didn't catch that. Say it again, a little BIGGER!!
Dryer Repair
