Wanted to know how to get the old water inlet out. I have the top of the washer off and everything unhooked from the old water inlet valve but it doesn't seem to want to just come right up. Is there something under that that needs to be undone first?
There are two screws that hold it on, from the service manual: Remove the two hex-head screws from the water inlet/dispenser valve assembly, and remove the assembly from the washer.
They are not that easy to see but you will find them.
