dcbradt
#1 Posted : Wednesday, March 8, 2017 4:02:37 AM(UTC)
dcbradt
when i first turn washer on, the water inlet valve lets cold water in, then after about 30sec. turns off and hums. I switch the plug ins(little elec. wires) and it runs again, then during rinse cylce, it does the same thing and I have to switch wires back, I've checked hoses, screens and all seem fine, I do not use the hotwater, and the hotwater is turned off from the wall. and yes, I have it set on Cold/cold
thanks
Darren
ThatGuy
#2 Posted : Wednesday, March 8, 2017 5:47:52 AM(UTC)
ThatGuy
Groups: Expert
United States
Try this, take the hot water hose and switch it for the cold water hose. Then switch the wires so that the hot water valve will now do the job that the cold water side used to do.
Then try it out, if it fills OK, that means the cold water side of your water valve is going bad.
If you provide the model number I could provide you with better help.
jimctec
#3 Posted : Wednesday, March 8, 2017 2:51:07 PM(UTC)
jimctec
Some of the inlet valves have a thermistor inside. Automatic temp control. If the incoming water is too cold it may be trying to add a little hot to warm it up. Try normal operation with both valves turned on at the wall.
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Water inlet valves burning out (Dishwasher Repair)
by Tydinelle 3/3/2024 4:06:06 PM(UTC)
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest 2/13/2024 3:32:15 AM(UTC)
Whirlpool Water Inlet Valve Repair for Leak (Refrigerator & Freezer Repair)
by ForumUser1 12/23/2023 12:57:44 PM(UTC)
Water Inlet Valve WR57X10033 / AP3189335 for General Electric DTL18ICSRRBS (Refrigerator & Freezer Repair)
by breckrider 1/18/2023 7:43:17 PM(UTC)
Replaced water inlet valve, still no ice or water (Refrigerator & Freezer Repair)
by Guest 7/3/2021 3:14:08 PM(UTC)
dishwasher not filling with water...already changed water inlet valve (Dishwasher Repair)
by jbonez 5/25/2021 5:32:22 PM(UTC)
Leaky new water inlet valve on whirlpool gold refrigerator (Refrigerator & Freezer Repair)
by Guest 4/4/2021 5:35:03 PM(UTC)
Water Inlet Valve for Whirlpool WRF560SEYW05 (Refrigerator & Freezer Repair)
by nycgene 7/30/2020 10:50:55 AM(UTC)
Noise after water inlet valve replacement (Refrigerator & Freezer Repair)
by Kristsivia 11/3/2019 4:29:36 PM(UTC)
GE washer replace WH13X10057 water inlet valve (Washer Repair)
by Cmath 3/9/2017 9:23:21 AM(UTC)
Water inlet valve leaking (Washer Repair)
by Jimh64 1/29/2016 7:31:50 AM(UTC)
Hot to replace water inlet valve on GE washer dryer combo WSM2700HCWWW? (Washer Repair)
by AbbyBrickman 1/4/2016 8:36:24 PM(UTC)
Water Leaking at Water Inlet Valve (Refrigerator & Freezer Repair)
by marshmore 12/24/2015 8:00:34 AM(UTC)
