As wash cycle started, stoped by opening lid to place item in and the closed lid and washer would not start
The lid switch is the most likely cause but it a little hard to check (harder than your normal lid switch) I don’t think I can explain it very well. I would suggest trying that first. Maytag Washer Repair Guide
