Discuss
water level control
 in
Washer Repair
I just replaced the belt and breaks on my washer and put everything back together, but now the water will
Appliance Repair Forum > Appliance Repair Help > Washer Repair » water level control
  #1 (permalink)
Old 05-13-2009, 08:16 PM
Junior Member
johnnybnice is on a distinguished road
Default water level control
Brand: Amana   Age: More than 10 years
I just replaced the belt and breaks on my washer and put everything back together, but now the water will not stop filling up? hmmmmm??!!
  #2 (permalink)
Old 05-14-2009, 03:02 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Please see this one that I just replied to
Dinger
__________________
  #3 (permalink)
Old 05-14-2009, 04:20 AM
Junior Member
Default will not agitate-everything else seems to work
the washer fills and the level now works, but now the washer will not agitate. the washer just sits there through the cycle, then when time is up it goes into spin cycle, so the tub does spin, but will not agitate, what could be wrong, could i have some wires hooked up wrong? there are two connectors, a red and a white one, could they be hooked up incorrectly?
  #4 (permalink)
Old 05-14-2009, 05:17 AM
Senior Expert
APP Volunteer
Default
A Model Number might help.
Also where are the two connectors?
Could be the level switch contacts which close to tell the machine that the unit is full of water and it should agitate are not closing.
__________________
  #5 (permalink)
Old 05-14-2009, 02:42 PM
Junior Member
Default
the model number on this Amana is lwd70aw, thanks
  #6 (permalink)
Old 05-15-2009, 02:30 AM
Senior Expert
APP Volunteer
Default
Cannot find a wiring diagram for this unit.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
timer control or water level control? Elehairyjob5 Washer Repair 3 02-18-2010 01:44 PM
which part do I need for water level control so washer does not over fill? Paul Bailey Washer Repair 2 08-15-2009 04:04 PM
Ice level control board Kit celcamcor Refrigerator & Freezer Repair 1 07-22-2009 09:54 AM
Water level does not shut off/ and it fills with water & drains but does not agitate dogwood100 Washer Repair 1 04-14-2009 05:20 PM
Water Level Control does not work darkhorse Washer Repair 1 08-30-2008 06:15 PM
