i had blankets in washer and left...the load ended up not being balanced and moved off platform, the blankets were still wet, water was drained...the washer does not spin, it does everything else...the tub is not spinning, is that something we can fix...finances does not allow me to call repairman...way to expensive.....:mad:
Take off the front cover and see if anything is jammed in the drain lines, the pump or between the tub and basket. If all is clear, operate the machine with the front cover off and see if the motor and transmission are turning when it is supposed to be spinning. If so, try changing out this part here Part number: AP4009132
