Discuss
Compact washer won't drain
 in
Washer Repair
My compact washer has been getting lazy about draining, first on the wash cycle, and then on the rinse cycle.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Compact washer won't drain
  #1 (permalink)
Old 07-03-2011, 10:44 AM
Junior Member
rogersboyz is on a distinguished road
Default Compact washer won't drain
Model Number: LCR5232HQ1   Brand: Whirlpool   Age: 5 - 10 years
My compact washer has been getting lazy about draining, first on the wash cycle, and then on the rinse cycle. It is worse with a full load. Sometimes it will not drain with a full load, but then will drain if some clothes are removed. I had a local repairman come to fix it, and he first suspected a blockage near the drain pump. He took the pump apart, inspected the drain hose coming into the pump, and the external drain hose. He checked voltage to the pump, and "dry" pump operation. He could not find any problem. When we ran the washer with no clothes, it worked fine. The washer was reinstalled, and the second time we used it, it refused to drain again with a full load. It is acting like there is a switch that shuts down the pump when the load is too big. Any ideas? I am now in $212, with no result. Thank you. Jeff Rogers 714.514.7380
Ads By Google
Related Models
Whirlpool LCR5232HQ1
Whirlpool LCR5232HQ2 Compact Automatic Washer
Whirlpool LCR5244AN0
Whirlpool LCR5244AN1
Whirlpool LCR5244AW0
Whirlpool LCR5244AW1
Whirlpool LCR7244DQ0
Whirlpool LCR7244DQ1
Whirlpool LCR7244DQ2
Whirlpool LCR7244DQ3
Whirlpool LCR7244DQ4
Whirlpool LCR7244DQ5
Whirlpool LCR7244DZ0
Whirlpool LCR7244DZ1
Whirlpool LCR7244DZ2
Whirlpool LCR7244DZ3
Whirlpool LCR7244DZ4
Whirlpool LCR7244DZ5
Whirlpool LCR7244HQ0
Whirlpool LCR7244HQ1
Whirlpool LCR7244HQ2 Compact Automatic Washer
Maytag LCRE200 Range - F/s Std Ele
Maytag LCRE300 Range - F/s Std Ele
Maytag LCRE305 Range - F/s Std Ele
Maytag LCRE350 Range - F/s Std Ele
Maytag LCRE355 Range - F/s Std Ele
Maytag LCRE383 Range - F/s Std Ele
Maytag LCRE400 Range - F/s Std Ele
Maytag LCRE600 Range - F/s Std Ele
Maytag LCRE650 Range - F/s Std Ele
Maytag LCRE655 Range - S/c F/s Ele
Maytag LCRE682 Range - S/c F/s Ele
Maytag LCRE683 Range - S/c F/s Ele
Maytag LCRE700 Range - S/c F/s Ele
Maytag LCRE750 Range - S/c F/s Ele
Maytag LCRE775 Range - S/c F/s Ele
Maytag LCRE800 Range - S/c F/s Ele
Maytag LCRE805 Range - S/c F/s Ele
Maytag LCRE883 Range - S/c F/s Ele
Maytag LCRG200 Range - F/s Std Gas
Maytag LCRG300 Range - F/s Std Gas
Maytag LCRG305 Range - F/s Std Gas
Maytag LCRG350 Range - F/s Std Gas
Maytag LCRG355 Range - F/s Std Gas
Maytag LCRG382 Range - F/s Std Gas
Maytag LCRG383 Range - F/s Std Gas
Maytag LCRG400 Range - F/s Std Gas
Maytag LCRG405 Range - F/s Cont Clean Gas
Maytag LCRG500 Range - F/s Std Gas
Maytag LCRG501 Range - F/s Std Gas
Maytag LCRG502 Range - F/s Std Gas
Maytag LCRG505 Range - F/s Std Gas
Maytag LCRG560 Range - F/s Std Gas
Maytag LCRG583 Range - F/s Cont Clean Gas
Maytag LCRG600 Range - F/s Std Gas
Maytag LCRG601 Range - F/s Std Gas
Maytag LCRG602 Range - F/s Cont Clean Gas
Maytag LCRG700 Range - S/c F/s Gas
Maytag LCRG705 Range - S/c F/s Gas
Maytag LCRG750 Range - S/c F/s Gas
Maytag LCRG755 Range - S/c F/s Gas
Maytag LCRG760 Range - S/c F/s Gas
Maytag LCRG760A Range - S/c F/s Gas
Maytag LCRG783 Range - S/c F/s Gas
Maytag LCRG800 Range - S/c F/s Gas
Maytag LCRG805 Range - S/c F/s Gas
Maytag LCRG860 Range - S/c F/s Gas
Maytag LCRG860A Range - S/c F/s Gas
Maytag LCRP200 Range - F/s Std Gas
Maytag LCRP205 Range - F/s Std Gas
Maytag LCRP300 Range - F/s Std Gas
Maytag LCRP382 Range - F/s Std Gas
Maytag LCSE400 Surface Unit - Ele
Maytag LCSE600 Surface Unit - Ele
Maytag LCSE601 Surface Unit - Ele
Maytag LCSG500 Surface Unit - Gas
Maytag LCSG501 Surface Unit - Gas
Maytag LCSG560 Surface Unit - Gas
Maytag LCSG600 Surface Unit - Gas
Amana LCU-514 Range - S/c S/i Ddraft Gas
Amana LCU-514D Range - S/c S/i Ddraft Gas
Amana LCU-514E Range - S/c S/i Ddraft Gas
Amana LCU-516D Range - S/c S/i Ddraft Gas
Amana LD10 Commercial Microwaves
Amana LD10D Commercial Microwaves
Amana LD10D2  Commercial Microwaves
Amana LD10MP  Commercial Microwaves
Amana LD10MPS  Commercial Microwaves
Amana LD510 Commercial Microwaves
Amana LD510D  Commercial Microwaves
Amana LD510M Commercial Microwaves
Amana LD510P  Commercial Microwaves
Amana LD510S Commercial Microwaves
Gaggenau LD816-610
Gaggenau LD816-620
Whirlpool LDA3000W0
Whirlpool LDA3000W1
Whirlpool LDA3000W2
Whirlpool LDA3000W3
Whirlpool LDA3005W0
Whirlpool LDA3005W1
Whirlpool LDA3005W2
Whirlpool LDA3005W3
Whirlpool LDA3800W0
Whirlpool LDA3805W0
Whirlpool LDA4000W0
Whirlpool LDA4000W1
Whirlpool LDA4000W2
Whirlpool LDA4000W3
Whirlpool LDA4005W0
Whirlpool LDA4005W1
Whirlpool LDA4005W2
Whirlpool LDA4005W3
Whirlpool LDA5300W0
Whirlpool LDA5300W1
Whirlpool LDA5300W2
Whirlpool LDA5300W3
Whirlpool LDA5380W0
Whirlpool LDA5380W1
Whirlpool LDA5380W2
  #2 (permalink)
Old 07-04-2011, 03:07 PM
Member
Ardvaark is on a distinguished road
Default
If the pump motor is turning and there are no clogs in the pump or drain lines, then the impeller is slipping on the pump shaft. Replace pump.
Ardvaark
  #3 (permalink)
Old 07-15-2011, 05:55 PM
Junior Member
Default compact washer - bum pump
Quote:
Ardvaark
Ardvaark - thank you very much for the correct advice. I replaced the pump and it is working perfectly.
  #4 (permalink)
Old 07-15-2011, 07:28 PM
Member
Default
Glad I could help!!
Ardvaark
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Compact Washer making a whirring sound when it spins. Scrapper Washer Repair 0 10-27-2010 05:23 PM
compact washer jimlorton Washer Repair 0 02-20-2010 01:02 PM
Ram does not compact lgreganti Trash Compactor Repair 0 01-18-2010 07:01 AM
compact refrigerator Jolds Refrigerator & Freezer Repair 0 08-21-2009 07:43 AM
compactor will not compact JFOSTER Trash Compactor Repair 1 05-09-2009 02:13 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
