My Atlantis washer seems to have a problem when set on gentle cycle. Sometimes when it is set to start, it just makes a clicking noise at the switch. When I pull it in and out a few times it starts to run. At times, it also enters this clicking state during a cycle. Only time it seems to do that.
If it otherwise is ok, and it sounds like it is, try replacing the timer.
