My washer will agitate and fill up with water, both on the wash cycles and the rinse cycles, but will not agitate on any of the cycles. Please let me know what the causes might be, what parts might be needed to fix it and the expense. Thank you. :)
If the machine will not spin out, then you will need to check the lid switch assembly. Check and make sure it is not broke, and the plunger is not broke as well. Here is the part number for the lid switch assembly, as well as a link to the parts diagram. Hope this helps. Part number: AP3100003
