| » Won't spin |
Model Number: WSSH300G0WW Brand: GE Age: 1 - 5 years
My washer just stopped spinning. The tub washes and empties but will not go through the spin cycle. I've put it in spin only and the pump will come on and run for a minute and then stop. The tub will turn 3-4 slow rotations in each direction and then will stop and beep. I've done the test by pressing the start and pause button and will get 4 beeps and then 2 beeps. Which if I understand tells me the door is closed. But the door opens and the lock does lock when I hear the initial click. Any help would be appreciated.
| Display Modes | |
| Whirlpool washer won't spin on rinse cycle or high spin | bry21317 | Washer Repair | 10 | 05-24-2011 12:25 PM |
| washer does not spin, fills up and drain the water nornal but do not spin | leaderman | Washer Repair | 0 | 10-04-2010 02:28 PM |
| motor, belt & trans pully spin, no agitation/spin cycle | slavens | Washer Repair | 2 | 05-08-2010 04:10 PM |
| Replaced clutch (fixed wet clothes after spin) makes a noise when it starts spin??? | mikeal21 | Washer Repair | 1 | 03-01-2010 06:21 PM |
| Frigidare front load washer will not spin durning final spin cyle | binky8992 | Washer Repair | 2 | 08-19-2009 06:29 PM |
