| » Water Does Not Drain Unless Extra Spin Cycles |
Model Number: WLW3500RBLWH Brand: Hotpoint Age: More than 10 years
great machine, but since 3 more people moved in it rinses/spins fine but clothes are still very wet unless extra spin cycles are used.
Also - it is slow to fill on the "cold water" setting. Cold water runs feely elsewhere in the house. I see the water pump is available for ~$35 - should I get one before I start digging in? Also - for my machine is their any related parts typically need replacing during a pump swap? the machine is difficult to access. thank you! Related Models |
Quote:
2) Replace the water inlet valve (#805 on the break down diagram). - The part number for the water inlet valve is AP2618763 Here are the break down diagrams for the Hotpoint washer Model WLW3500RBL Gene.
__________________
Professional appliance repair in Orange County, California. |
The most common problem with this particular pump is water leak but...you never know.
__________________
| Display Modes | |
| Won't spin between cycles | dcavers | Washer Repair | 6 | 08-23-2008 08:06 PM |
| Spin and pump cycles stop and start, washer won't drain | grosshaus | Washer Repair | 1 | 03-31-2008 03:10 PM |
| water won't drain on some cycles but does on delicate cycle | ffq | Washer Repair | 1 | 12-06-2007 01:57 PM |
| water will not drain or spin | chefray | Washer Repair | 1 | 09-29-2007 06:02 PM |
| Washer won't drain during spin cycle. Water Pump Belt discovered on floor | sandydjdm | Washer Repair | 1 | 08-14-2007 08:41 PM |
