kathy48
#1 Posted : Tuesday, July 27, 2010 8:18:07 AM(UTC)
kathy48
When I start my Gibson Washing machine it will fill and start the cycle for washing. After a couple of minutes it stops and does not start up for 2-3 minutes. Then it starts tumbling again and stops after a few minutes. When it starts I hear a humming sound that is normal. When it stops there is no sound. Could it be a sensor for overheating? Or is there another reason for the stopping and starting?
sidfink43
#2 Posted : Wednesday, July 28, 2010 5:43:01 AM(UTC)
sidfink43
This sounds like your motor is failing. When your motor has problems, a thermal protection function shuts it down.
Given other problems that this model, which is a Frigidaire built machine, has had, and the fact that you have had 10 years+ usage I would say the time has come to replace it.
kathy48
#3 Posted : Thursday, July 29, 2010 6:42:47 AM(UTC)
kathy48
I called a repair man in and it turns out that the door lock is faulty. By replacing the lock that solved all the problems.
sidfink43
#4 Posted : Thursday, July 29, 2010 9:04:19 AM(UTC)
sidfink43
Interesting! That's unusual with your symptoms, but the door lock assembly does fail regularly on these machines, and I am glad to here you got it fixed.
Sometimes we don't get it right, so Thanks for the update
Gibson Washer (Washer Repair)
by vanclif 6/26/2012 5:34:56 PM(UTC)
by DarylKKK 5/14/2011 1:25:41 PM(UTC)
gibson washer won't spin (Washer Repair)
by wulff26@live.com 4/26/2011 5:45:36 AM(UTC)
Gibson Washer - timer not advancing/no spin (Washer Repair)
by jharrington1222 2/2/2011 1:57:55 PM(UTC)
gibson washer (Washer Repair)
by George Leonardi 6/10/2010 7:03:02 AM(UTC)
by mike welsh 5/18/2010 4:22:35 PM(UTC)
Gibson Washer leaking (Washer Repair)
by Daisyrose09 12/12/2009 7:32:10 PM(UTC)
gibson washer wont spin (Washer Repair)
by meandmy7 10/22/2009 8:16:27 AM(UTC)
Gibson washer won't fill (Washer Repair)
by JohnMadison 8/9/2009 7:45:15 AM(UTC)
gibson washer won't drain (Washer Repair)
by mem 10/14/2008 10:09:29 AM(UTC)
