Discuss
ice cubes
 in
Refrigerator & Freezer Repair
Hi this is my first post any help would be appreciated I have a ge hotpoint side by side hss25ifmdww
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » ice cubes
  #1 (permalink)
Old 06-23-2008, 03:09 PM
larry218 larry218 is offline
Junior Member
larry218 is on a distinguished road
Default ice cubes
Model Number: hss25ifmdww   Brand: Hotpoint   Age: 1 - 5 years
I have a ge hotpoint side by side hss25ifmdww it has a crushed ice,cube ice, and water dispenser the problem was that i could not get any ice out crushed or cubed but i could get water after removing all the ice and clearing the dispenser I can now get crushed ice ,water but no cubes it doesnt matter which is selected crushed or cube all i get is crushed. any help would be appreciated
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-24-2008, 03:40 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Larry,
Measure the resistance across the solenoid (#378 on the break down diagram) terminals. It suppose to be about 40 Ohms.
If the reading is wrong then replace the solenoid.
If the reading is correct then check for 120 VAC to the solenoid while the ice dispenser calls for cubed ice and light switch is depressed.
Here are the break down diagrams for the Hotpoint refrigerator Model HSS25IFMDWW
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 06-24-2008, 03:47 PM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Gene, if you don't mind I'd like to add to this. Take the bucket out, and at the bottom left of where the auger fork is, make sure you can freely move the solenoid up and down, you can do that with your finger. Also make sure the wire that extends from the back of the bucket is in that hole with the solenoid in the down position.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #4 (permalink)
Old 06-24-2008, 04:38 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Adam,
It's always good to have someone backing you up.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE ice maker crushes, no cubes nainex9 Refrigerator & Freezer Repair 3 09-15-2008 08:32 PM
Ice cubes turn into clumps iamafallenangel Refrigerator & Freezer Repair 2 05-11-2008 12:37 PM
Ice cubes fogy Janek2 Refrigerator & Freezer Repair 1 04-18-2008 05:50 AM
Ice cubes in bin frozen together Mike20080325 Refrigerator & Freezer Repair 3 03-31-2008 01:49 AM
ice maker crushes, no cubes sfshipley Refrigerator & Freezer Repair 7 03-12-2008 04:04 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
