Discuss
ice maker problems
 in
Refrigerator & Freezer Repair
My ice maker stopped working with the forks in a 12:00 position. I was advised to replace the module
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » ice maker problems
  #1 (permalink)
Old 06-11-2008, 08:48 PM
oldg oldg is offline
Junior Member
oldg is on a distinguished road
Question ice maker problems
Model Number: KSRS27QXWH01   Brand: Kitchen Aid   Age: More than 10 years
My ice maker stopped working with the forks in a 12:00 position. I was advised to replace the module and I did. Now the forks are in the correct 2:00 position, but the unit will not cycle through or fill w/ water. I checked the water line and it is clean and not frozen. The water dispenser on door works, so I don't think the water valve is the problem. But what is?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-12-2008, 06:41 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Remove the front cover from the ice maker. Using a 14GA insulated piece of wire, short the test points "T" & "H" to run the motor. Leave the jumper in for a half of a revolution and remove it. The water valve should be energized in the last half of the revolution.
Post the results.
Here are the break down diagrams for the Kitchen Aid refrigerator Model KSRS27QXWH01
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 06-13-2008, 08:57 AM
Junior Member
Thumbs down
I shorted the T and H points and nothing happened. A local tech advised that I short the N and M points, also. Nothing happened with that either. What now? thanks!
  #4 (permalink)
Old 06-13-2008, 04:55 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check for 120VAC between the test points "L" & "N" (make sure the probes go in 1/2"). If there is 120VAC then the motor is bad or you installed the module improperly.
If there is no 120VAC then check for continuity the thermal fuse (spliced into the black wire in the wire harness).
__________________
  #5 (permalink)
Old 06-14-2008, 02:25 PM
Junior Member
Lightbulb
The fuse is the culprit - it is blown. Is it a problem cutting it out and direct wiring the black line, or do I need to replace the harness, with a new fuse? THANKS!
  #6 (permalink)
Old 06-16-2008, 04:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The fuse is blown due to excessive heat. In that case you have to replace the harness and the thermostat in the ice maker, but I would recommend to replace the whole ice maker because of very low rate of success on ice makers repair.
- The part number for the wire harness is AP3133181
- The part number for the thermostat is AP3135377
- The part number for the alumilastic cement (must be used for the thermostat installation) is AP3103415
- The part number for the ice maker is AP2984633
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
problems with ice maker and water dld5258 Refrigerator & Freezer Repair 2 03-20-2008 11:54 AM
Ice Maker problems Charlie L. Refrigerator & Freezer Repair 0 03-11-2008 07:12 AM
ice maker / water dispenser problems krkoch Refrigerator & Freezer Repair 0 03-08-2008 03:56 PM
Norge Ice maker problems bkricks Refrigerator & Freezer Repair 0 01-18-2008 10:35 AM
Whirlpool Ice Maker Problems ponyboy Refrigerator & Freezer Repair 7 11-14-2007 09:25 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
