Discuss
Whirlpool Icemaker problem
 in
Refrigerator & Freezer Repair
My icemaker quit working. I checked to see if there was any water in the despenser and there was not.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Whirlpool Icemaker problem
  #1 (permalink)
Old 03-12-2008, 12:03 PM
Hilton Hilton is offline
Junior Member
Hilton is on a distinguished road
Default Whirlpool Icemaker problem
Model Number: ed2jhgxrb00   Brand: Whirlpool   Age: 1 - 5 years
My icemaker quit working. I checked to see if there was any water in the despenser and there was not. I replaced the water inlet valve at the bottom of the refrigerator but still no ice. What now?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-13-2008, 12:00 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Hilton,
The model number you posted does not come up.
Verify and repost it, please.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 03-13-2008, 12:07 PM
Junior Member
Default Whirlpool Ice Maker Problem
ED2JHGXRB00 is the number I ordered the inlet vavlve for, which were correct. Since I posted before, I have shorted the T&H terminal and the motor runs for a moment then stops. I took the module loose and put it back together. I finally did get it to make one cycle of ice.
  #4 (permalink)
Old 03-13-2008, 12:48 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sounds like the problem is a bad thermostat. Hopefully replacing the thermostat will solve the problem.
- The part number for the thermostat is AP3135377
__________________
  #5 (permalink)
Old 03-16-2008, 05:51 PM
Junior Member
Default Replaced thermostat
Okay I replaced the thermostat. It started working, at least the motor started and it has put water in the icemaker. I'm waiting for ice. One more question. You didn't mention I needed the aluminum putty for the back of the thermostat. Do I need it or is it going to work without it?
  #6 (permalink)
Old 03-16-2008, 06:20 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The new thermostat should come with the installation instructions.
I'm not sure about the aluminum putty. You have to follow the instructions from the package.
__________________
  #7 (permalink)
Old 03-20-2008, 12:07 PM
Junior Member
Default Still no ice
Just followup. The icemaker made one cycle of ice and nothing more. The instructions with the thermostat said to make sure to use Cement Alumilastic or it may not work properly. Of course nothing was mentioned with the thermostat when I purchased it. After searching numerous sites for the best price I have ordered it ($21.00 for a little bitty tube). I assume it fills the gap between the thermostat and the icemaker. As soon as I get it and put the cement on, I'll let you know if it works. I didn't know if you had ever heard of it before. If that don't work I quess I'll just have to replace the entire icemaker.
  #8 (permalink)
Old 03-31-2008, 07:53 AM
Junior Member
Default still not working
I finally got the aluminum cement for the thermostat. I applied it and put the ice maker back together. As soon as I plugged it in the icemaker started to cycle. It put water in the mold and the water froze. The icemaker never got any further in the cycle. I know the heater is working. The only other thing I know is to repalce the module. Any suggestions????
  #9 (permalink)
Old 03-31-2008, 12:59 PM
Jmorgando Jmorgando is offline
Junior Member
Jmorgando is on a distinguished road
Default Whirlpool Ice maker
i'M HAVING A PROBLEM WITH MY ICE MAKER, IT WILL NOT MAKE ICE AND WATER RAN ALL OVER. i HAVE ORDERED A nEW ICE AMKER, TO SEE IF THAT WILLL FIX THE PROBLEM...
  #10 (permalink)
Old 03-31-2008, 01:35 PM
Junior Member
Default
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Icemaker Door Problem Kathy Refrigerator & Freezer Repair 12 12-21-2007 09:02 PM
Icemaker Problem dbjackel Refrigerator & Freezer Repair 2 12-17-2007 07:08 PM
Icemaker problem nhfr Refrigerator & Freezer Repair 0 11-17-2007 10:47 PM
icemaker problem kpriest Refrigerator & Freezer Repair 1 08-30-2007 04:53 PM
Sears icemaker problem standback27 Refrigerator & Freezer Repair 0 08-20-2007 02:58 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
