| » Fridge not cooling |
Model Number: RS267LASH Brand: Samsung Age: 1 - 5 years
I have a Samsung RS267LASH and the refridgerator side does not seem to be cooling. I've read everywhere that they have a ton of defrost problems and I think this may be the case with mine. My question is...the "fresh" bins with their own temperature control seem to get cold. Is there something I'm missing here, or something I should check?
B Ads By Google Related Models |
I have exact the same problem that your having on the same style fridge RS267LASH, if you would happen to fix it let me know what you did so i can do the same, and in return if i correct my problem i'll post what i did to repair it, Thanks
I repaired my Samsung RS267LASH, my symptoms was the freezer was staying cold, but the fridge was not, i pulled the inner panels out, and done some resistance checks on thermistors, and the defrost sensor, and found it to be open, there was a total of 4 sensor in the fridge, and if they are check there should be some value showning when you use a multimeter, i replace the thermal switch, and all is working like it's suppose too
| Display Modes | |
| Fridge not cooling | ebin | Refrigerator & Freezer Repair | 2 | 09-11-2009 05:49 AM |
| Fridge Not Cooling | guero22 | Refrigerator & Freezer Repair | 6 | 07-13-2009 07:08 AM |
| Fridge not cooling | jsmith7740 | Refrigerator & Freezer Repair | 2 | 05-24-2009 07:57 AM |
| GE fridge not cooling once again | rmila75 | Refrigerator & Freezer Repair | 1 | 08-21-2008 07:02 AM |
| fridge not cooling | nikkilynn29 | Refrigerator & Freezer Repair | 1 | 08-11-2008 08:36 PM |
