I have a side/side the Fridge part was fine but the Freezer Part wasn't freezing , The compressor was hot to the touch and then I notice the fan had some dust on the motor cleaned it and it came right back on, after 30min rechecked the compressor it was a little cooler, so I replaced the Capacitor, after 30 more min it got much cooler, but no change on the freezer side , coils were frozen only at the top of the coils, freezer fan motor running , so I replaced the thermostat thinking that might help no such luck. frozen up again but the compressor is very cool to the touch, and know my fridge side isn't getting as cold as it should be, Need help Thank You
