Just_me
#1 Posted : Sunday, July 17, 2016 8:09:30 PM(UTC)
Just_me
I am having a frost problem in my freezer, and thus blocking airflow to the refrigerator. A repairman replaced the JAZZ Board and said there was nothing else that could go wrong. He did not do a diagnostic test of any kind. We have made many attempts to get him back, and every time he stands us up. This has been going on since June 1st.
Every 10 - 14 days the freezer gets plugged up, and I have to defrost by opening freezer door and putting a fan in there. Then everything works great for another 10 - 14 days.
I found an online diagnosis sheet but everything checks out okay. When I put the freezer into forced electronic defrost, the heater element comes on and starts the defrost mode. It is my understanding that this wouldn't happen if something was wrong.
Also, the freezer and refrigerator are not over crowded, and the door seals are in perfect condition.
Any ideas?
Jim
AUricle
#2 Posted : Monday, July 18, 2016 7:50:40 AM(UTC)
AUricle
J_m,
How are you forcing the unit into defrost mode?
Do you have a defrost TIMER or adaptive defrost controls?
Just_me
#3 Posted : Monday, July 18, 2016 8:50:15 AM(UTC)
Just_me
I have not seen a defrost timer on this fridge, and I'm not sure what adaptive defrost controls are. I was told that the Jazz Board operates everything.
To do an electronic forced defrost:
1: Press and hold fridge door switch
2: Press the fridge (-) button 3 times and release door switch (step one and two must be done within 10 seconds)
3: display will read "f" and "d" (this means forced defrost)
4: Press fridge (-) button once more to confirm and an "S" will display (this means short defrost mode)
5: To select long defrost mode press the (+) button on fridge controls. This allows you to toggle back and forth between short and long cycle.
6: When you have made your selection press the (-) button on fridge side of control to start the defrost.
Warm Refrigerator - #HSS25GFTA WW (Refrigerator & Freezer Repair)
by Edwv30 5/5/2024 12:17:37 PM(UTC)
GE warm refrigerator, new inverter. (Refrigerator & Freezer Repair)
by Guest 11/24/2023 4:51:12 AM(UTC)
Freezer warm refrigerator cold (Refrigerator & Freezer Repair)
by oldfartsexpress 5/27/2018 8:34:46 AM(UTC)
Warm Refrigerator, Cold Freezer (Refrigerator & Freezer Repair)
by phillb 2/27/2013 5:24:40 AM(UTC)
Warm Refrigerator (Refrigerator & Freezer Repair)
by mfjohnston 6/8/2012 2:31:45 AM(UTC)
Jenn-Air warm refrigerator section, freezer fine (Refrigerator & Freezer Repair)
by j34castro 7/26/2011 12:51:39 PM(UTC)
warm refrigerator (Refrigerator & Freezer Repair)
by gvernon 5/30/2011 6:02:58 AM(UTC)
Warm refrigerator freezer OK (Refrigerator & Freezer Repair)
by jzielinski49@comcast.net 4/17/2011 8:54:53 AM(UTC)
warm refrigerator but freezer is fine (Refrigerator & Freezer Repair)
by bmt274 10/22/2010 10:38:10 AM(UTC)
Cold freezer, warm refrigerator (Refrigerator & Freezer Repair)
by dgandt 7/26/2010 11:16:32 AM(UTC)
Failing icemaker and warm refrigerator (Refrigerator & Freezer Repair)
by cshulamit 6/11/2010 7:52:44 PM(UTC)
by Nicholson 5/7/2010 10:08:33 AM(UTC)
by dnelsen 3/22/2010 6:23:19 AM(UTC)
warm refrigerator, frost on inside back panel (Refrigerator & Freezer Repair)
by mbnash 3/23/2009 9:44:19 PM(UTC)
Warm refrigerator (Refrigerator & Freezer Repair)
by jordad 3/23/2009 9:44:45 AM(UTC)
