solonoid valve doesnt shut water off even with solonoid unplugged.new valve
"new valve" Was the above a question or that you have tried a new valve. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman "new valve" Was the above a question or that you have tried a new valve. its a brand new valve
Then it sounds like you received a bad replacement valve.
With it unplugged it should be closed.
One thing to check is the pressure on the water line. Most valves use the water pressure to help close them. |
