Samsung refrigerator. My refrigerator is not cooling correctly. The freezer is cold on the bottom ( it is a side by side). The temperature is reading approx 70 deg in both ref and freezer at the top. I purchased a new evaporator fan motor as it was not running only to find out I have no power to the motor. A service tech advised I need a new control board. I replaced it with a new one, no change. I ordered a second one, no change. Fan is not blocked with ice. What should I try next? Thanks :confused:
