miketomp56
#1 Posted : Friday, September 25, 2009 3:55:48 PM(UTC)
miketomp56
system will not go into defrost there are two sensors and one defrost t-stat. how do I force this system into defrost to check amps on my heaters, (how many amps),also what tells the mother board when it is time for defrost
applianceman
#2 Posted : Friday, September 25, 2009 5:45:47 PM(UTC)
applianceman
The only way to force it into defrost is to use a jumper wire on the motherboard. I personally do not recommend doing so. The time between defrost cycles is determined by the motherboard based on how many time the door is opened as well as how long the door stays opened.
I recommend defrosting the coils and checking ohms across the heater. There should be around 20-35 ohms or so.
Refrigerator repair guide
Bottom Freezer No defrost Maytag mbf2256keq2 freezer at -5 fridge at 64 (Refrigerator & Freezer Repair)
by Stahlmaster 9/6/2021 6:54:13 AM(UTC)
"Repaired" no defrosting (Refrigerator & Freezer Repair)
by brian@briandean.net 12/21/2015 7:21:19 AM(UTC)
Iced up evap coils, no defrost (tough one) (Refrigerator & Freezer Repair)
by gmab 5/29/2015 6:43:46 AM(UTC)
No defrosting, freezer and refrigerator's temperature is rising (Refrigerator & Freezer Repair)
by mllambi 6/21/2014 1:03:33 PM(UTC)
frigidaire refrigerator side by side no defrost (Refrigerator & Freezer Repair)
by gregaguilar 12/11/2013 2:40:37 PM(UTC)
by chuckcandoit 2/13/2012 8:18:13 AM(UTC)
Amana bottom freezer buzzing/clicking, no defrost (Refrigerator & Freezer Repair)
by bgjohnstonpm 4/28/2011 9:30:27 AM(UTC)
GE Side by side no defrost (Refrigerator & Freezer Repair)
by Rick Ches 4/18/2011 4:36:53 PM(UTC)
Samsung No Defrost on Both Sides (Refrigerator & Freezer Repair)
by thxyung 10/9/2010 10:03:58 AM(UTC)
by susanfung 9/28/2010 4:25:27 PM(UTC)
Will refrgerator work with no defrost timer (Refrigerator & Freezer Repair)
by tarbetb 6/9/2010 2:41:17 PM(UTC)
no defrost timer that i can find (Refrigerator & Freezer Repair)
by ralph everett 12/29/2009 11:17:53 AM(UTC)
by applmike 4/18/2009 8:09:49 AM(UTC)
No defrost, no schematic (Refrigerator & Freezer Repair)
by Washer123 2/21/2009 3:30:50 PM(UTC)
Freezer full of food and no defrost (Refrigerator & Freezer Repair)
by bongeno 11/21/2008 7:49:01 PM(UTC)
