Rick Ches
#1 Posted : Monday, April 18, 2011 4:36:53 PM(UTC)
Rick Ches
I would like to find a schematic, I am having a defrost problem. i have checked the timer it is cycling and sending power to the heater, but from there i dont know were the wires go or what they are supposed to do. The freezer has to heaters I found one of them to be bad so I installed the wires to just the one heater trying to get it to come on but it will not heat up. Need help. Thanks
#2 Posted : Tuesday, April 19, 2011 4:36:00 AM(UTC)
Here are your parts.
GE likes to keep everything a secret so I cannot supply a wiring diagram.
The diagram for your unit may be in the machine compartment under the unit.
Here is an example of a side by side with a mechanical timer.
http://www.applianceaid.com/images/sampleSxSdiagram.JPG
Since you have 120 volts up at the heater/thermostat combo I would replace the heater assembly.
Looks like it includes both heaters and the defrost thermostat.
I believe it is wired defrost thermostat then heater 1 then heater 2.
It should measure around 20 ohms.
Note the defrost thermostat must be frozen to get a reading as it opens just above freezing.
I would not try running just a single heater, you will have a high current flow and it could weld the defrost timer contacts together.
