| » Freezer not cold |
Model Number: MSD2454GRW Brand: Maytag Age: More than 10 years
My freezer is defrosting and not cold at all...cool at best. I checked the coils and they are fine, free from ice....is there anyone who can tell me why the freezer is not working?
Charlie Ads By Google Related Models |
Here are your parts, includes a wiring diagram.
Parts for Maytag MSD2454GRW Refrigerator - AppliancePartsPros.com First you have to determine what is running and what is not. Are both the condenser/compressor fan and the evaporator/freezer fan running? Is the compressor running? Usually you can hear it but you should also be able to feel it vibrating and it should be warm. If yes to the above are they cycling or on all the time? If on all the time remove the cover in the freezer so you can inspect the evaporator coils. If they are heavily iced/frosted over you may have a defrost problem. If there is no frost or just frost in one area (usually where the freon enters the coils), it is probably a sealed system problem. Be sure that the compressor has run for an hour or so before doing this check. If you do it shortly after a defrost cycle then you will come to the wrong conclusion.
__________________
| Display Modes | |
| Freezer Cold But Not Freezing; Fridge Compartment Cold & Seems Fine | ChuckM12 | Refrigerator & Freezer Repair | 1 | 08-29-2012 07:51 AM |
| Kenmore- freezer is cold but not freezeing- Fefrig is cold | dan11 | Refrigerator & Freezer Repair | 1 | 02-07-2012 02:27 AM |
| Outside Refrig/Freezer in Garage does not stay cold in cold weather | verno1 | Refrigerator & Freezer Repair | 2 | 12-14-2010 12:07 PM |
| Kenmore w/ Freezer bottom drawer - Blowing Cold Air but not cold enough | tvGhouse | Refrigerator & Freezer Repair | 0 | 02-25-2009 02:50 PM |
| Fridge & Freezer Cycle Cold To Warm Back To Cold | terkel | Refrigerator & Freezer Repair | 1 | 09-25-2007 02:58 AM |
