| » Icemaker problems |
Model Number: SXD26VE Brand: Amana Age: 5 - 10 years
Icemaker quit filling with water. Valve is good. Replaced icemaker and it made about 3 trays and quit filling. Replaced icemaker again. Same issue. I can jump L and V test points and water flows. Voltage at L and N is 124V. I can jump T and H to start the cycle. Voltage is still 124V at L and N; however when it cycles around to close the contact for the water valve, I only get 94V at V and N. The valve will not operate at 94V. I cannot find why the voltage drops. Any ideas.
Did you replace the ice maker together with the wire harness or just the ice maker?
What is the part number of the new ice maker? Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
It now makes some ice; but not much. Some of it is hollow. I have turned the fill adjustment almost a full turn CCW. Seems to fill sometimes and not others. It acts like the valve is working intermittently; but when I jumper it, it works perfectly every time.
What is the exact measured temperature in the freezer?
__________________
Quote:
Jamosteve, I'm going to take a stab at this and throw a few things for you to check. When you jump it out the valve should stay energized for approximately 7 to 7.5 seconds. I would check it at the valve itself if it were me. During that time you should be getting about 4.5 oz of water in a glass. If it's engergized for the right amount of time yet you're not getting enough water either the valve is acting up or the pressure to the valve from your house may be an issue. Especially if you're using one of those self piercing water valves under your sink. If it's not staying energized for that 7 seconds, that's going to be an IM problem, considering you've maxed out the water inlet adjustment. The 94 volt part is strange. That's coming from the IM head itself so it still sounds like it could be the IM. One more thing. May sound odd, but -5 if really cold. It's a wonder your not getting hollow cubes due to the IM short cycling. As in the t-stat in the IM is being satisfied before the ice is fully frozen.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
If 115 volts is applied to the icemaker water solenoid with a line cord, you should get "normal" water flow. When the icemaker sends voltage down to the solenoid, sometimes the voltage is reduced due to a burnt wire someplace in the fridg. I have seen this happen often. The problem is inside the fridg where it is impossible to fix.
__________________
| Display Modes | |
| GE Icemaker problems | kjp1015 | Refrigerator & Freezer Repair | 6 | 07-28-2011 03:48 PM |
| problems with icemaker | tommyboy64 | Refrigerator & Freezer Repair | 0 | 06-23-2011 03:31 PM |
| Icemaker problems | VOLLER | Refrigerator & Freezer Repair | 3 | 08-04-2010 10:05 AM |
| IceMaker Problems | 36td | Refrigerator & Freezer Repair | 0 | 06-08-2010 11:51 AM |
| Icemaker problems | AustinBrooks | Refrigerator & Freezer Repair | 5 | 10-06-2009 05:52 PM |
