ice dispenser not working. research indicated bad motherboard because when you press lever for ice there is no sound, the auger & solenoid don't move) & it stops the fan & compressor. But now there is a distinct clacking sound from the rear that last about 5 minutes every couple of hours & i wonder if it's a bad relay. can it be one or the other or is it both? also, if i choose to do nothing & just live without the dispenser for a while is it harmful? :confused:
