Fridge is not cold and I have ice build up on the back wall of the freezer. Will not make ice. I replaced the thermost on this model but now I think it could be the defrost heater. I do not know what it looks like, nor where to find it. Is it hard to do, or should I just buy a new fridge? At least 15 years old. Thank you very much for your help.
Groups: APP Team
Hi. Locate the defrost timer (to the right from the thermostat you replaced). Using the flat screw driver slowly turn the shaft CW until the unit stops. After 5 min. check if the defrost heaters are melting the snow. If they do work - replace the defrost timer Part number: WR9X489
