will not dispense water from door, did defrost freezer then water worked but then stopped again, how do i fix Thanks Gary
Hi Gary, Very likely the problem is a frozen water line inside the freezer door. If this is correct then the solution is to replace the whole freezer door. It can not be taken apart by not very smart GE design. Perform the test as described in the attached file to determine exactly what is wrong. - The freezer door Part number: WR78X11721
