Hello - The freezer part of my frig is working fine it is 0 degrees. No ice build up. The opening to the frig part is wide open with no blocks. The evaporator fan is running I can hear it and see it. But there is no air being blown into the frig and it is not very cold. The fan seems to be running very fast but if it is going bad could the RPMs be down just enough to not blow air into the frig area? Could someone please help-- Thank you...
