Hello- The freezer part of my frig is working fine it is 0 degrees. The evaporator fan is running I can see it and hear it. The opening from freezer to frig where the air goes thru is wide open but there is no air being blown into frig compartment and it is not very cold. Could you offer suggestions please... Thank you. I was thinking that if the fan is going bad it might not be putting out the correct RPMs. But it looks like it is running very fast..
