We have a model KSSC48FMS 03, serial number QU0516008 Kitchen Aid refrigerator/freezer, over the last month we have seen several strange things happening with the unit; the first thing we noticed was a beeping, upon investigation we found the display unit off, it did not appear that the on/off button had any affect but the beeping corresponded to the display cycling on & off, we removed power from the unit by unplugging from the outlet in an attempt to reset with no luck, it stayed that way for a few days and the temperature maintained normal settings of -5 & 35 degrees, then after about 3 – 4 days the display came back and all seemed to be OK. About a week after that we noticed the temperature in the refrigerator side varying from 35 to 41, it did that for about a week then we noticed that it was starting to make a noticeable motor or humming sound emanating from within the freezer section and the temperature was steady in the freezer at -5 and the refrigerator was still varying 35 – 41, now that noise is very loud and the temp in the refrigerator seems to be more on the 41 side but still occasionally will go to 35.
Read more: http://forum.appliancepartspros...-temp.html#ixzz1kW9ke9vM http://forum.appliancepartspros.com
replaced main control board, all is ok now
Originally Posted by: sschmal replaced main control board, all is ok now How much did that cost you ? Were you able to to do it yourself ? I've got a similar problem with my Kitchenaid K-SSS-48QMB01 It beeps 3x then a steady tome ? I have vacumened the whole thing out and taken a soft duster wand and got 99% of any dust off all the coils and fan blades. Any suggestion on how to get this irriatating noise silenced ? Luckily my TV rooms and Master Bdrm is on the other side of the house so we can at least sleep. Thanks in advance for any and all help !
