My S/S refrig-freezer works fine for a day or two, freezer at 0 and frig at 34+ as set. Then it will start to warm up frig and freezer to 40 degrees. The system will restart if I turn the frig control to off and then back on. Then it will work for day or so. Defrost timer???? Help
If the fridg completely shuts down, I would tap on the cold control, probably intermittent AP3037004
Originally Posted by: richappy If the fridg completely shuts down, I would tap on the cold control, probably intermittent AP3037004 tHANKS MUCH AS THAT IS WHAT IS THE PROBLEM. THE FIX IS TO REPLACE??? IF SO, CAN A NON REFRIG PERSON DO IT? I LIVE 400 MILES FROM THE NEAREST REPAIR FACILITY.
Just make sure you route the sensing wire exactly where the old one was.
