Discuss
Help!
 in
Refrigerator & Freezer Repair
Ok, we need help. The Fridge worked fine when we plugged it it. Ran a new water line to it.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Help!
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 11-11-2007, 12:48 PM
Tim Baumann Tim Baumann is offline
Junior Member
Tim Baumann is on a distinguished road
Question Help!
Model Number: TFH24PRSAAA   Brand: GE   Age: 5 - 10 years
Ok, we need help. The Fridge worked fine when we plugged it it. Ran a new water line to it. It seemed to be making ice right away.
The fridge light switch was broken so HE tried to fix it. Eventually it shorted out.
Day 2 the water from the ice maker line froze up and leaked down, sounded like water was dripping on hot coils.
Unplugged the darn thing.
Did something short out?
Plugged it back in, the freezer light now flickers. HELP!
Signed, "The Wife"
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-12-2007, 12:53 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Tim's wife
The first thing I would do is to see how the fridge works without the ice maker. Lift all the way up the arm on the right side of the ice maker. It should turn the ice maker off and then run the fridge for a few days under you personal supervision. If anything wrong, let me know.
The next step is to check the ice maker and the water valve, but lets do one thing at a time.
About flickering light, check the light bulb for loosen connection. If this is not the issue then replace the light switch. Unplug the fridge first.
- The part number for the light switch AP2067519
Good luck.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 11-12-2007, 01:48 PM
Junior Member
Question
Thanks for replying.
Yes, we are running the fridge with the ice maker off. Should we have done that when we first plugged it in? Is that why the end of the hose froze on day 2? It had already made a cycle of ice, then where the water fills the ice tray froze and water started being diverted down the sides. How do you keep it from freezing? The freezer light didn't start flickering until after that happened.
The original problem was the fridge side lower door switch that makes the light go off when you close the door. Eventually, after working on it, that shorted out. Wondering if that might have shorted something else out? We have already ordered that switch.(#WR23X10143)
The ice dispenser worked great for years before we moved it here. Would love for it to work again.
Thanks!
The Wife
  #4 (permalink)
Old 11-12-2007, 02:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the problem is a bad water inlet valve which is not closing completely after the ice maker filled with water.
- The part number for the water valve AP3672839
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
