Was having issues with defrost system so I replaced heater (which was broken) thermostat and timer. Before entire coil unit was frosted over. Now it is just maybe the bottom row (4-5 Coils) and its a solid block of ice? I also replaced the icemaker nipple assembly and saw that it was dripping water. I have completely defrosted again should I just wait and see or would something else be causing this? Also when I look at the manual for this should the heater be on top of both coils or top and bottom of lower one? I currently have it on top of each coming down. Any ideas would be greatly appreciated.
THIS FORUM IS DEAD!!!!!!! |
That makes sense that is why top coils are staying clear and bottom ones are not. Think I have learned alot on here thanks again for your help.:)
