I'v been reading a lot of the post about clicking sounds coming from the board. I have no frig at all except for lights. My sound is coming from the bottom left of the board where there are a couple of relays. I di remove and inspect the board for burn marks found none.My question is do I get the board or should I check other parts first as the board is expensive Thank You Dave:confused:
