SmokyJoe
#1 Posted : Wednesday, August 20, 2008 10:36:30 PM(UTC)
SmokyJoe
The ice maker leaks water into the ice tray, and when the water freezes, it forms chunks of ice in the tray. Also, the arms that eject the ice from the mold freeze up and fail to operate. Also some of the cubes come out hollow. Suspect a faulty inlet valve, but want to be sure before replacing the valve.
libertyappl
#2 Posted : Thursday, August 21, 2008 8:09:05 AM(UTC)
libertyappl
I would suspect the valve too. Try a small test to see if it's leaking.
Take the hose off while the wire connectors are attached and see if it lets water out, you may want to use a pan or bowl to catch any water. You may also need someone to advance the icemaker until it calls for water.
Hope that helps
Nat
SmokyJoe
#3 Posted : Thursday, August 21, 2008 8:58:56 AM(UTC)
SmokyJoe
Hope that helps
Nat
Nat, thanks for the tip. Could you please describe in a little more detail how to do this test, as I am not that knowledgeable about icemakers. Do you mean to take the hose off the valve from the rear supply line, or is there a hose on the valve outlet inside the freezer compartment? Also, how does one advance the icemaker?
Thanks,
Joe
libertyappl
#4 Posted : Thursday, August 21, 2008 9:05:49 AM(UTC)
libertyappl
The water valve on the back of the refreigerator. disconnect the waterline going up the back of the frig. leave the electrials plugged up. see if any water comes out of the valve.
Try that first and post your results.
Nat
LG french door refrigerator ice maker fan not working (Refrigerator & Freezer Repair)
by md5757 11/6/2023 11:27:11 AM(UTC)
Frigidaire Refrigerator Ice Maker and Water Dispenser not working (Refrigerator & Freezer Repair)
by kehoetj 5/9/2023 3:57:44 PM(UTC)
Kitchenaide Refrigerator ice maker and interior lights not working (Refrigerator & Freezer Repair)
by tpet308 1/27/2021 2:04:14 PM(UTC)
Whirlpool WRX735SDHZ refrigerator ice maker (Refrigerator & Freezer Repair)
by billsfanva 1/15/2020 6:43:06 AM(UTC)
GE GSHS5KGXCCSS Refrigerator Ice Maker Issue (Refrigerator & Freezer Repair)
by lsedels 10/15/2019 7:27:23 AM(UTC)
GE refrigerator ice maker rear support posts. (Refrigerator & Freezer Repair)
by Menkemf 8/16/2019 2:49:38 PM(UTC)
Samsung Refrigerator Ice Maker Alarm. (Refrigerator & Freezer Repair)
by fordguy101 4/26/2019 1:13:37 PM(UTC)
GE Refrigerator ice maker overflowing!!! (Refrigerator & Freezer Repair)
by porksoda 11/4/2017 9:48:41 PM(UTC)
Frigidaire Refrigerator Ice Maker leaks (Refrigerator & Freezer Repair)
by TNPutter 7/31/2017 3:40:08 AM(UTC)
Kitchenaid Refrigerator ice maker (Refrigerator & Freezer Repair)
by southerncooker7173 8/25/2016 11:01:00 AM(UTC)
Frigidaire Refrigerator Ice Maker not working (Refrigerator & Freezer Repair)
by sstollings 3/23/2016 6:31:16 AM(UTC)
Samsung refrigerator ice maker not working (Refrigerator & Freezer Repair)
by D71Collier 10/30/2015 10:06:23 AM(UTC)
Electrolux Refrigerator ICE MAKER not working (Refrigerator & Freezer Repair)
by Tom McBride 8/6/2014 3:43:56 PM(UTC)
LG Refrigerator Ice Maker Leaking (Refrigerator & Freezer Repair)
by jimdeprado 4/17/2014 5:06:08 AM(UTC)
Samsung French door refrigerator ice maker (Refrigerator & Freezer Repair)
by katiebell 5/3/2013 9:41:52 AM(UTC)
