mjlewandowski
#1 Posted : Monday, May 24, 2010 9:14:11 AM(UTC)
mjlewandowski
When turned on the oven does not light regularly. Sometimes there will be a big poof and the smell of gas. At times that will occur throughout the baking cycle. Baking results are not consistent.
#2 Posted : Monday, May 24, 2010 1:38:55 PM(UTC)
Which oven (upper or lower) gives you problems?
mjlewandowski
#3 Posted : Monday, May 24, 2010 7:47:49 PM(UTC)
mjlewandowski
Sorry...my problem is with the lower oven.
mjlewandowski
#4 Posted : Tuesday, May 25, 2010 6:39:34 PM(UTC)
mjlewandowski
It's the lower oven...any suggestions on what might be wrong?
mjlewandowski
#5 Posted : Tuesday, May 25, 2010 6:40:47 PM(UTC)
mjlewandowski
Gene,
#6 Posted : Wednesday, May 26, 2010 9:04:52 PM(UTC)
Check the Bake burner for a burned through holes. If it's fine, replace the Bake igniter.
- The Bake igniter Part number: AP2009619
mjlewandowski
#7 Posted : Thursday, May 27, 2010 2:32:39 PM(UTC)
mjlewandowski
Gene,
Will changing the ignitor solve the problem with the intermittent (but not frequent) explosions during baking? What causes this to happen?
#8 Posted : Thursday, May 27, 2010 2:58:44 PM(UTC)
It can be because of a bad burner or a bad igniter. That's why you have to check the burner first.
bosanci28
#9 Posted : Thursday, May 27, 2010 8:47:15 PM(UTC)
bosanci28
for some reason i have problem with the lower igniter
is not lighting anymore,, hmmm,any ideas what to start changing first?
thanks
