I am converting a Whirlpool Stove Top from Natural Gas to Propane. When looking for repair parts on-line, I don't see orrifices specific for LPG. Is it possible that this unit (SC8630EXN-3) doesn't require a new orrifice part and just needs the current orrifices adjusted instead? How about the regulator? Please help! Thanks!
Originally Posted by: DeanHask I am converting a Whirlpool Stove Top from Natural Gas to Propane. When looking for repair parts on-line, I don't see orrifices specific for LPG. Is it possible that this unit (SC8630EXN-3) doesn't require a new orrifice part and just needs the current orrifices adjusted instead? How about the regulator? Please help! Thanks! Hi my name is norman i had the same problem .So I called up Whirlpool cop. they sent me the kit, and thats where Iam at, because the kit inclouded (7) color coded orrifices, no instuction on drawing mystove top hase only (4) burnners . Iam lost dont know how to go from their . I need some help on installing the orrifices ; If I had just got 4 it might be easer but then I have the color code to deal with Iam lost can anyone help thanks onelove Norm.
Groups: Guests
Originally Posted by: Norman Shillingford Hi my name is norman i had the same problem .So I called up Whirlpool cop. they sent me the kit, and thats where Iam at, because the kit inclouded (7) color coded orrifices, no instuction on drawing mystove top hase only (4) burnners . Iam lost dont know how to go from their . I need some help on installing the orrifices ; If I had just got 4 it might be easer but then I have the color code to deal with Iam lost can anyone help thanks onelove Norm. Hello, I did some research and located the answer to the inquiry on page one of the installation instructions: Note: This cooktop is manufactured for use with NATURAL gas only.
