tsk
#1 Posted : Sunday, February 28, 2010 1:18:09 PM(UTC)
tsk
Model: Kitchen Aid KGRA806PSS00
Problem: Oven Burner Lights for a few seconds and turns off. While the oven igniter is firing or the burner is lit there is 9.8 volts at the gas valve. When the flame goes out the voltage returns to 0. Gas valve ohm reading is broiler to common 215 ohms / oven burner to common 216 ohms. The broiler burner has the same problem. Main oven sensor has a reading 1093 ohms. I have replaced the main electronic board not the dsi and the oven burner and the problem remains. Cooktop works properly. Wall out voltage 118 volts and has been checked for polarity. HELP! :confused:
Kitchen Aid oven problem (Oven Repair (including Ranges and Cooktops))
by Rawger11 9/2/2014 11:13:56 AM(UTC)
