tpon
#1 Posted : Wednesday, May 14, 2008 3:54:37 PM(UTC)
tpon
I have a Modern Maid double oven, the top oven won’t light, the igniter turns red but the gas does not flow, the igniter will turn off after about 10 min. the broiler and bottom oven works fine.
Model Number PG0191U
Serial Number 6773460
Igniter by Norton Model Number is 501
No one has this igniter
glen65
#2 Posted : Thursday, May 15, 2008 8:09:55 AM(UTC)
glen65
I cant seem to pull anything up on the model you listed
please check the model and serial tag on the oven.
In most cases the glowbar ignitor itself is responsible for this.
It is connected in series with the burnner valve.
The ignitor can still operate but at the same time not
allow enough current to pass through it to open the burnner valve
so that the gas can flow through to the burner.
Thermador Gas oven won't light (Oven Repair (including Ranges and Cooktops))
by Guest 8/1/2023 8:48:27 AM(UTC)
Help, my gas oven won't light..... (Oven Repair (including Ranges and Cooktops))
by lharrell79 3/17/2016 10:13:10 AM(UTC)
Kitchenaid Gas Oven Won't Light (Oven Repair (including Ranges and Cooktops))
by Chris Ricc 1/7/2015 8:13:37 PM(UTC)
GE gas oven won't light -- igniter works (Oven Repair (including Ranges and Cooktops))
by markdraper 5/26/2011 10:37:41 AM(UTC)
Geneal Electric XL44 gas oven won't light (Oven Repair (including Ranges and Cooktops))
by watchwoman1950_2005 12/26/2010 11:26:18 AM(UTC)
by jennblueskies 5/13/2010 8:26:01 AM(UTC)
by homeboy 1/30/2010 1:50:06 PM(UTC)
Tappan Gas oven won't light (Oven Repair (including Ranges and Cooktops))
by ghengiskenn 9/29/2009 5:26:08 PM(UTC)
by mauricimo 5/31/2009 6:12:56 AM(UTC)
Gas oven won't light... (Oven Repair (including Ranges and Cooktops))
by johnny63 12/23/2008 4:19:21 PM(UTC)
Gas Oven won't light (Oven Repair (including Ranges and Cooktops))
by LQQKING4U 12/14/2008 3:09:46 PM(UTC)
Gas oven won't light/goes out (Oven Repair (including Ranges and Cooktops))
by jgbradley 11/29/2008 6:06:57 AM(UTC)
Magic Chef gas oven won't light (Oven Repair (including Ranges and Cooktops))
by koohgar 7/23/2007 5:57:24 PM(UTC)
