BHcub
#1 Posted : Saturday, February 13, 2010 9:13:54 AM(UTC)
BHcub
I need to replace screws for a baffle in the ss spinner drum which is totally enclosed inside the plastic drum. Is there an easy way to do this or do I have to totally remove the ss spinner. If so do I start from the back spindle in the rear of the plastic drum and if I remove the bolt will the ss spinner become free enough to get my hands between the ss drum and the plastic drum to tighten the screws?:confused:
Appeared to be a simple fix but hmmm maybe not.
Any ideas would be thanked and welcomed.appreciated
BHcub
#2 Posted : Saturday, February 13, 2010 7:48:57 PM(UTC)
BHcub
Dont do just finished hire it out had to take off door remove front face lift top remove remaining front face found sludge all in drum cleaned for hours had access to screw on baffle put it all back together exhausted hire it out!
