kdraisey
#1 Posted : Wednesday, February 10, 2010 12:12:35 PM(UTC)
kdraisey
dishwasher will not do the heavy wash cycle or the rinse only cycle
#2 Posted : Thursday, February 11, 2010 2:16:33 AM(UTC)
Replacement parts for MAYTAG MDBTT60AWQ Dishwasher - Undercounter | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/docs/wiring/TechSheets_11_17_09/Schematic%20-%20W10179503.pdf
Try the diagnostics.
Since only 2 buttons do not work and it looks like there is no common connection which only involves 2 switches, it sounds like the control board is gone.
I would still check the control panel (keypad) switches with a meter.
Also try the cleaning procedure.
If the switches check out OK and the cleaning does nothing then odds are the control board is gone.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
