Elements will not go down to low heat. Still too hot on low. Oven works fine. Local technician has replaced terminal block at incoming pigtail, and all 4 manual control switches. No change. :confused:
if burners get red on high ,and then red goes when turning down ,it maybe normal for this range, unless wattage of burners is not correct , if these are original burners ,i would doubt that
OOOkkkaaayyyy!!! How do you recognize the wattage on an existing burner? And are other wattages readily available?
the wattages should be engraved on burner. call whirlpool they should be able to tell you correct wattages with model#
