was doing a load of laundry as i put the next load in everything was normal untill i pressed start it only beeps twice is there a way to restet my washer or aanything else to do to get my washer workin. Its a ge front loading washer
If your machine is less than 1 year old you should be covered by factory warranty.
If you want to do some troubleshooting look under the top for tech notes that will take you through some diagnosis and testing.
If you have any questions please post the result of your troubleshooting and your full model number.
