techwreck
#1 Posted : Wednesday, January 13, 2010 7:14:52 AM(UTC)
techwreck
Frigidare washer overflows on full load only. Small and meduim loads work OK. Pulling the plug does not stop flow. I have to shut off water supply. Is this a pressure switch or water valve problem (or both)?:confused:
applianceman
#2 Posted : Wednesday, January 13, 2010 8:29:53 AM(UTC)
applianceman
Water valve for sure if it doesn't stop when you remove power. Hope this helps!
Clothes Washer Repair Guide
techwreck
#3 Posted : Wednesday, January 13, 2010 8:51:02 AM(UTC)
techwreck
But, why does the water stop when the water level is set to Small and Medium loads? I fiddled a little more, and the problem only occurs on the cold water shut off when the water level is set for Full loads.:confused:
applianceman
#4 Posted : Wednesday, January 13, 2010 1:52:00 PM(UTC)
applianceman
When you pull the plug and it still runs water you rule out everything but the water valve.
techwreck
#5 Posted : Wednesday, January 13, 2010 2:53:40 PM(UTC)
techwreck
I get the message. Thank you for your sage advice.
